Sponsored by:
Sponsored by:
Horrible vibration when opening trunk
Old 01-28-2011, 11:38 PM
Young_Gun
Young_Gun's Avatar
Default Horrible vibration when opening trunk
Every time I open the trunk, I get this horribly loud vibration instead of the nice clear "pop" sound. At first I thought it was the spoiler being loose, but we checked that and it isn't. We checked all the trim pieces and they're good.
I've also noticed that the lid isn't always shutting the first time.
This really makes me angry, especially because I haven't done any mods to the rear of the car (no decklid covers or anything)
And when I met up with a local group tonight and had to open the trunk to get my coat, they all laughed at me.
It probably hasn't helped that I have tested the emergency trunk release, but all the noise started at random - months after the last time I pulled the handle.
I'm really desperate for answers here - especially since I finally prettied up the rear end with a set of sequential tail lights
Thanks
Young_Gun is offline
Old 01-29-2011, 06:33 AM
Recon111
Recon111's Avatar
Your emergency trunk release hasn't reset itself, It's fighting with the electrical trunk release. Talk to a Ford Mechanic, It's probably an easy fix.
Recon111 is offline
Old 01-29-2011, 07:08 AM
Nuke
Nuke's Avatar
I'd begin by lubing the latch assy and looking for any places that show some rubbing.
Nuke is offline
Old 01-29-2011, 09:28 AM
Young_Gun
Young_Gun's Avatar
Would resetting the computer (again) do the trick? It did start (I believe) after the last time I reset the computer when I put in a CAI
Can someone open their trunk and show me a picture of what the latch should look like (as in what position its in)
Thanks
Old 01-29-2011, 09:47 AM
Recon111
Recon111's Avatar
YG
I would start by asking a Ford Mechanic. It may be something as simple as pushing a reset button like on the fuel pump. You may have to release it after the trunk is shut. I don't know.
If you don't want to do that then try to pull the trunk release again, this time look in there to see if it goes anywear after you release it.
Recon111 is offline
Old 03-20-2012, 04:24 PM
richmod
richmod's Avatar
My 06 GT has developed this exact problem. Did you ever find the cause?
richmod is offline
Old 03-20-2012, 04:28 PM
Young_Gun
Young_Gun's Avatar
New trunk lock motor
Easy fix
Old 03-21-2012, 12:44 PM
richmod
richmod's Avatar
Easy fix
Is that the same as the Trunk Latch Assembly? Part #43200? Can't find a listing for trunk lock motor.
richmod is offline
Old 03-21-2012, 02:34 PM
Young_Gun
Young_Gun's Avatar
Yeah, should be
Old 03-21-2012, 11:30 PM
Moderator
JimC's Avatar
My wife's 2006 Focus would do that. After having the lock replaced twice, the latch assembly replaced twice, I asked them "can you check the alignment of the latch and the plate, maybe it isn't lining up properly"
It was the alignment - it would work fine for awhile and then it would be off a hair and buzz instead of pop open. The remounted everything and adjusted it and no problem ever again.
JimC is offline
Quick Reply: Horrible vibration when opening trunk
