Mustang Stalling, cut off while making a turn
Good Evening all. Just FYI I did search around for my issue before posting a thread, just couldn't find anything to fit my issue specifically.
Well this morning my mustang would not turn over after the first initial try, second try it started fine. So I let it warm up as usual. about 1/2 mile down the road I came to a stop sign, tried to make the turn but the car shut off. Put it back in park and cranked it right back up. After that whenever I come to a stop, the rpm's get really low, almost to the point of stalling out. I had axle back Pype bombs put on the car last week. This is the only other mod in addition to a Steeda CAI and a bamachips 93 octane tune.
So where should I start to look? Battery? Fuel?
I checked for codes, i have none at the moment.
Thanks in advance for your insight.
If we had carbs I'd say you had a bad float, but we don't...
Are you having any electrical indications of a bad battery or some issue with the charging system? At low idle your alternator could have a low or no output. Compound that with a weak battery and it could mess with the electronics.
If you're still using the OE MotorCrap battery, then I'd say you're overdue. And these charging systems are so sensitive that a battery problem can degrade an alternator. Good idea to have both load tested. The forum is full of threads about bad batteries and alternators causing electrical gremlins.
Guess I will do the fuel filter swap or run the seafoam.
