Wiper Fluid Squirter Problem
Old Feb 9, 2011 | 07:32 PM
Young_Gun's Avatar
Young_Gun
Default Wiper Fluid Squirter Problem
When I bought the car back in late October, it came completely out of wiper fluid - not a drop.
I filled it up, and now when I pull the lever to spray fluid, only a little tiny spray comes out that doesn't even make it to the windshield. When I pull it again, it sprays just fine.
Any ideas?
Old Feb 9, 2011 | 07:53 PM
AzPete's Avatar
AzPete
Sounds like there could be a blockage that only opens with the extra pressure from the second+ pumping. Remove the hose from the pump and shoot some air pressure thru it.
Old Feb 9, 2011 | 08:08 PM
Young_Gun's Avatar
Young_Gun
Easy to do?
Old Feb 9, 2011 | 08:14 PM
Nuke's Avatar
Nuke
It almost sounds like it's losing it's prime after sitting for a bit which could indicate a leak in a hose from the tank to the nozzels. That might explain why you're initial attempt is a dribble (priming the lines) and the subsequent trys work fine.
Old Feb 9, 2011 | 08:23 PM
Young_Gun's Avatar
Young_Gun
In which case I should..?
Old Feb 9, 2011 | 09:28 PM
ikemikestang's Avatar
ikemikestang
How many times did you do this? The first time probably did not work because the hose was empty, squirting the first time built up liquid in the hose.
Now if you did this more than once and still does the same. Check the hose.
Old Feb 9, 2011 | 09:39 PM
daredevil95's Avatar
daredevil95
Follow the hoses from the squirters all the way to the motor/tank. Look for a leak and if you can't find a hole....replace all the hose....bring in a piece of hose to an auto parts store. You could buy 5' for around $3.00....it's inexpensive. If that doesn't fix it....the problem is probably with the motor.
Old Feb 10, 2011 | 06:53 AM
Nuke's Avatar
Nuke
Originally Posted by daredevil95
... If that doesn't fix it....the problem is probably with the motor.
More likely the pump. But I still suspect he's losing his prime (aren't we all) since it eventually works fine.
Old Feb 10, 2011 | 07:47 AM
AzPete's Avatar
AzPete
Disconnect the hose at the pump and apply some light air pressure.
While the hose is off, see if the pump actually squirts a good stream.
Old Feb 10, 2011 | 08:05 AM
Young_Gun's Avatar
Young_Gun
That sounds good (and easy, haha) I'll do tomorrow afternoon
Thanks
jma2
Jul 10, 2023 01:00 AM
PNYXPRESS
Sep 14, 2015 09:50 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
5.0 kevo
Sep 3, 2015 06:24 PM
