Unique Situation - Cluster Swap - Disabling Passive Anti Theft System (PATS)
If you order (for those interested in doing this in the future) one from a dealer and they order the one that coincides with your VIN number then it should be a direct swap.
We will see about that when I get mine. It shipped today.
Alright, I was wrong.... At least partly anyway.... I tried loading the tune that disables my PATS but no joy, I don't think the tune worked in that area.
I got my new cluster and plugged it in and ran into the same thing DMHINES ran into.... Damn car wouldn't start because of the anti-theft system I'm guessing. I guess the only way to get past this is to have the dealer load the "as-built" data for me. Now the hurdle will be finding a dealer around here smart enough to do that. It won't be easy to find......
- I won't be able to go to the Ford dealer to get them to reprogram my keys because my keys are no longer "used" since I have the Digital Guard Dawg push start button system installed. My car uses key fobs now and no keys at all. When they hooked my system up the left one of the key heads with the factory chip in it behind the steering wheel so that the PATS system will read it.
- My install guy said that the dealer won't be able to reprogram that because of the way it's set up now.
Anybody have an idea if disabling the PATS system before the cluster swap will solve my problem?
Once that is done push button start installer puts new key behind steering wheel ?
JoshyGT
Sep 19, 2017 08:52 PM
Sep 8, 2015 11:50 AM
