New 2011 GT 5.0 Manual
Tried to ask this in the street/strip section and got a message I could post there?
Been a while since I've had a performance car with a 6 speed manual.
I would like to know how to light the tires up without moving?
Thanks in advance,
Jim in Sequim
Thanks in advance,
Jim in Sequim
Burnout? No difference between a 5 or 6-speed.
Here you go:
http://www.youtube.com/watch?v=rSwOTV-jbns
Here you go:
Basically the idea is that you're hitting the gas and brakes at the same time, but the engine is going to over power the rear brakes which then lets you spin your tires while not moving forward. Key is to press the brakes just hard enough to not start moving, but not so hard that you keep the wheels from spinning.
I never did a long burnout, probably about a second at most, but I got a standing burnout just by turning off traction control and stomping on it in 1st gear. Lots of noise and rubber flying, but I didn't go forward at all.
A linelock would be the preferred way but like others said...the 5L is a high revver, drop the clutch at 6k rpm and hold on. Should be good for a second gear burnout on street tires.
But break that puppy in first. I wouldn't start beating on it till I had at least about 5k miles on the car.
