Rear suspension squeak
Old Feb 23, 2011 | 09:17 PM
AllGT's Avatar
AllGT
Originally Posted by CincyGT2009
Assuming it is the stabilizer bar bushings, what would you use to lube them and is there something that can be sprayed rather than disassembling everything?
Great opportunity to upgrade to some BMR LCA's and swaybar. Then you'll have lube ports (not going to say nipples)... two birds one gun.
Old Feb 24, 2011 | 06:03 AM
Norm Peterson's Avatar
Norm Peterson
WD-40?
You really need to get whatever you use in between the bar and the bushing rather than just spraying the outside and hoping that some of it eventually works its way in. I've used a marine silicone paste of some sort for similar purpose with polyurethane.
Norm
Old Feb 24, 2011 | 12:28 PM
CincyGT2009's Avatar
CincyGT2009
I guess I'm worried about spraying something that might degrade the rubber... I know the solvents in some lubricants do not play well with certain polymers. Hmmm...
Old Feb 24, 2011 | 12:35 PM
ShaneM's Avatar
ShaneM
graphite powder?
Old Feb 24, 2011 | 01:01 PM
incorrigible's Avatar
incorrigible
Whatever you do spray there will only be a temporary fix. I recall the same issue on the 60's Mustang upper control arm bushings. Spray down with WD-40, wait a week or two and the squeak is right back.
Bushing replacement is the only true permanent fix.
Old Mar 3, 2011 | 03:36 PM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by grabber blue gt
I am now recently getting a squeak over bumps coming from the rear of my car. I originally thought it was just dirt and salt, but I cleaned everything the other day with the hose, and its still occurring. Any guesses on what it could be? Would the dealer be able to fix it?
Hi grabber blue gt,
Have you been able to get this issue resolved or take it in to your dealer yet? If not, I’d like to check into it for you. Just send me your mileage, dealer, contact info, and VIN.
Deysha
Old Mar 3, 2011 | 08:08 PM
CincyGT2009
I would be VERY interested in the result here. I have a little over 1000 miles left on my warranty and would like to have this fixed too...
Old Mar 3, 2011 | 10:40 PM
grabber blue gt's Avatar
grabber blue gt
Deysha I just sent you a message, and thanks for chiming in to help the situation.
I am still getting the squeak, but I am going to take another look at it tomorrow when I lift the car back up. I hope I find the problem, cause the car is 9k miles old and I bought it in august.
Old Jul 16, 2012 | 10:59 PM
ghostly echo's Avatar
ghostly echo
Its the lca
thats the noise mine made, sway the car back and forth when it starts making the noise get down on the ground and place your hand on the lca driver side it will stop making the noise.
Old Jul 16, 2012 | 11:11 PM
09cs's Avatar
09cs
Glad someone broguht this thread back up.
My car has a HORRIBLE rear end squeaking when every I go over bumps. Grabber Blue GT did you ever solve yours?
