2011 GT/CS front valance installation with pictures.
Unclip the temp sensor. It is easier to remove the clip from the valance after the valance is off of the car.
Remove this screw. there is one on each side.
Remove all bolts marked with red arrows.
These screws(1 each side) are easy to get out with a stubby screw driver.
Pull the corners away from the body, and cover them with a rag or t-shirt to prevent paint damage. The valance can now be pushed/pulled forward away from the bumper cover. This shows where the tabs are located along the bottom. The top tabs are not held with friction like the bottom ones are.
Install in the reverse order. Make sure you cover the ends to prevent paint damage.
Before.
After.
Before.
After.
Before.
After.
Before.
After.
