speedometer?
Old Mar 3, 2011 | 04:25 PM
KonaStangPete's Avatar
KonaStangPete
yep get yourself a tuner and it should fix it right up, or just gotta remember that your goin faster than the speedo says, btw I assume your a fan of Eric koston op?
Old Mar 3, 2011 | 05:03 PM
ShaneM's Avatar
ShaneM
Originally Posted by grabber blue gt
ahhh **** I just put mine on and realized I never checked the speedo. I went from 19" wheels to 18" wheels (cant remember the exact tire sizes but they are 255 & 285) so I am sure my speedometer is off a bit. I can fix this with my sct right?
i bet your 18" and 19" arent any different with teh taller tires, i went form 19 to 18 and the speedo was right on.
Old Mar 3, 2011 | 06:44 PM
akdoggie's Avatar
akdoggie
The original size on the v6 was 215-65R16.
If his speedo is set @ the 16 wheel rate, then he is going 64 when his speedo reads 60 with the 20 inch tires. With the 235-50R18's he had first, he was actually doing 59 with it read 60. Go figure. Bigger, wider tire, more clearance at the axle, yet less diameter.
So anyways, when the speedometer reads 65, you are actually doing 69.8 mph. Hope that puts it in perspective.
Old Mar 3, 2011 | 07:40 PM
grabber blue gt's Avatar
grabber blue gt
Just checked with my gps earlier, and the speedo is spot on... OP I would try checking your speed with a gps before you do anything.
Old Mar 3, 2011 | 08:13 PM
markkk's Avatar
markkk
Originally Posted by Nuke
Even with the calculators and the manufacturers specs, you still encounter errors. I prefer to use my GPS and then adjust using the SCT, regardless of what the calculators say.
Snazzy move.
articman
Jun 21, 2018 11:45 PM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Nurdyguy
Aug 21, 2015 10:23 PM
danclint
Nov 28, 2004 10:32 PM
Leadfoot
Sep 10, 2004 03:05 PM
