07 shelby gt po642 code
Old Apr 9, 2011 | 01:28 PM
bowman shelby's Avatar
bowman shelby
Default 07 shelby gt po642 code
po642 code car is hard to start and runs rough. any one have any ideas?
Old Apr 9, 2011 | 04:32 PM
SpartaPerformance's Avatar
SpartaPerformance
This DTC is set due to an under voltage condition of the VREF circuit
• VREF circuit short to ground
• Damaged sensor
• Incorrect harness connection
Do anything to the vehicle recently that involved disconnecting any wiring??
Old Apr 10, 2011 | 11:40 PM
bowman shelby
Default dead shelby
the car will start some times and run about 200 rpm and die. Spark plugs look wet with fuel acts like no spark
Old Apr 11, 2011 | 07:17 AM
Nuke's Avatar
Nuke
Hope this helps: http://www.justanswer.com/ford/4ptjo...191-p0642.html
Old Apr 14, 2012 | 07:54 AM
samer_143's Avatar
samer_143
Default same problem
Hi (bowman shelby),
have you solved the your car problem?? because I have the same problem in my Mustang that RPM won't go above 3000RPM and showing the same code!!!
If you have fixed the problem , please pass it to me I am struggling
Old Jan 21, 2024 | 09:14 PM
Mvrder3v's Avatar
Mvrder3v
He did you ever get this fixed just got this problem today
Old Jan 22, 2024 | 12:58 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
This will help you troubleshoot the problem:
https://www.obd-codes.com/p0642
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Bokeo
Oct 10, 2015 08:28 PM
ChampInSD
Oct 2, 2015 04:55 AM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
