Anyone have the CDC center vinyled?
Hey guys, I recently cracked the center of my chin spoiler and was looking to I bondo it and then throw a piece of matte black vinyl on the center...has anyone done this....to give it this kind of look...
I don't want to professionally paint it since I don't have that kind of money right now....I was thinking vinyl is cheap...Do you thing if I sanded it down and sprayed it with spray paint it would look right?
I kept loosing traction in the snow in a parking spot, so the car kept hitting the parking block...I am atempting to spray it right now..just sanded it down and patched up the crack..waiting for it to dry so I can sand it down...the flat black I got doesn't look to flat to me lol..but we will see..I also order the vinyl to put on top in case I messed the paint job up..
well I just finished...pretty much it was a fail...nothing would really hold the cracked together so instead I just threw on a piece of duck tape which holds it perfectly but looks bad. I will just take it off when I receive the vinyl...
before starting...
sanding...
sanded through the clear-coat..u can see how deep the rock chips got through
tried using drywall tape before applying the bonding stuff
gave up and just put a piece of duct-ape over the crack and painted over it...
before starting...
sanding...
A better way to do it would be to reinforce it from the back, then fill the crack in the front. Then you could wrap it in vinyl if you wanted.
However, I will tell you that vinyl doesn't hold up very long on the front of a vehicle, especially on the lower portion of the bumper. When rocks hit it, it simply tears.
