Creaking Front End
Old May 8, 2011 | 09:53 AM
rocky321's Avatar
rocky321
Default Creaking Front End
08 GT. Automatic 87,000 miles. I have this fairly audible creaking sound from in front end during take off from a dead stop. Don't hear it when I first start driving, but it will start after driven for a while.
Old May 8, 2011 | 12:07 PM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Thee is a TSB on this.
If your car was built before 10/06 Then you need to replace your limited clutch pack.
If not you just probably need to add some friction modifier to the rear end.
Other than that you may have broken a bar.
Take it in and have them inspect your front suspension
If all looks ok just add some friction modifier then do some figure 8's at low speeds to force the modifier in.
I just got through doing this on my 08 Shelby.
I had the new clutch pack already and the culprit was needing the friction modifier.
Good luck!
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
the5
Sep 19, 2015 06:13 PM
Sparks_88
Sep 8, 2015 01:06 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
