Airaid CAI insert
Old May 15, 2011 | 02:24 PM
92hatchLX's Avatar
92hatchLX
Default Airaid CAI insert
Instructions said to leave it in. Can I remove it since I am tuned? It looks like it restricts air flow and possibly smooths out the air for the MAF.
Old May 15, 2011 | 03:14 PM
yourmyboybh1026's Avatar
yourmyboybh1026
The insert is to keep around the same air flow as the stock intake. That is what makes it a non-tune intake. If you take it out obviously there is a lot more air going threw and it turns into the roush intake. If you have a tune for the CAI then you can take out the insert.
Old May 15, 2011 | 03:46 PM
Nuke's Avatar
Nuke
Your tune should be specific to the CAI (w/o the insert) in order to benefit the most. Are you running canned or custom tunes?
Old May 15, 2011 | 03:49 PM
92hatchLX's Avatar
92hatchLX
Everything is in my signature. Running custom Bama tunes. It's tuned for the exhaust and intake. This should change the butt dyno readings when I take it out
Old May 15, 2011 | 10:57 PM
92hatchLX's Avatar
92hatchLX
Wow, I didn't think that removing the reducer would make this huge of a difference but holy crap. Note to others, if you are tuned for the intake remove the insert! I'm sure that most of you know this already.
baddog671
Jul 26, 2016 01:20 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
junior04
Sep 28, 2015 10:53 AM
firecoyote
Sep 27, 2015 02:37 PM
Sep 16, 2015 07:53 PM
