new coolant issues
Old May 22, 2011 | 04:12 PM
07vbluestang's Avatar
07vbluestang
Default new coolant issues
i installed the frpp h.o. whipple s/c last march. when adding the antifreeze at the end of the install we added zerox G-05. so we used the 60% distilled water and the 40% zerox G-05. also 1 bottle of water wetter. now this year i noticed like black lumps of mud looking objects in the overflow tank. there is no water in the oil. please help with your suggestions.
Old May 22, 2011 | 07:50 PM
SpartaPerformance's Avatar
SpartaPerformance
That doesn't sound good at all. Were you able to flush out all the original coolant? I'd flush the ENTIRE system and check with manufacturers and see which one of the items you're using is not compatible, when you have non-compatible coolants that's what happens they clump and clog everything.
Old May 22, 2011 | 08:25 PM
07vbluestang
i believe we didnt flush the original system when we installed the s/c. we just topped it off with Zerox G-05 and distilled water and a bottle of water wetter. i will have it flushed and go back with the original motorcraft antifreeze. in the whipple instructions it says you can use the Zerox G-05.
Old May 22, 2011 | 09:45 PM
2007CalSpec's Avatar
2007CalSpec
I drained the radiator before my Whipple install but didn't flush the whole system. I've also used Zerex-G05 and distilled water and added a bottle of water wetter. I haven't had any problems.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
wraith777
Sep 28, 2015 10:49 AM
