2005 GT Help
Old Jun 2, 2011 | 12:01 PM
TammyT's Avatar
TammyT
Unhappy 2005 GT Help
Hello all,
New to the forum. Need a little help. My 05 has been sitting since December (i know, i know, couldn't be helped) and won't start. Turns over, but wont crank. Any ideas?
Old Jun 2, 2011 | 12:30 PM
adj86's Avatar
adj86
Fuel Pump maybe? I worked on a friend's Tahoe, and it would turn over, but not start. We put a little gas in the throttle body and it cranked and then immediately died once the fuel was consumed. It ended up having to have the fuel pump replaced.
Old Jun 2, 2011 | 12:35 PM
Whipple's Avatar
Whipple
are you out of gas? if you left it sitting at a quarter tank then you need to...
1) get a few gallons of gas and put it into the tank
2) put your pedal to the metal 2 times, hold each time for one second
3) try starting the car, it should turn on after 5-8 seconds
(personal experience)
Old Jun 2, 2011 | 12:53 PM
Alec's Avatar
Alec
Battery
Old Jun 2, 2011 | 01:05 PM
oneoption08's Avatar
oneoption08
I think you mean it cranks but won't start. First step is to pull any codes (DTCs).
Old Jun 2, 2011 | 01:16 PM
TammyT's Avatar
TammyT
Put new gas in before trying to crank. Brand new battery.
Old Jun 2, 2011 | 01:34 PM
defiance's Avatar
defiance
Turn the key all the way to the on position (last position before starting), you should hear the fuel pump come on, do you hear anything?
P.S in the driver's side kickpanel there is a fuel reset button, just below the hood pull. Id give that a shot.
Old Jun 2, 2011 | 01:46 PM
TammyT's Avatar
TammyT
Yes. Very slight low hum. Have made several attemps with starting fluid, but as soon as it burns off engine dies.
Old Jun 2, 2011 | 02:55 PM
Lifter583's Avatar
Lifter583
I am thinking the old gas has varnished the injectors shut...may have to have them removed and cleaned...
Old Jun 2, 2011 | 03:01 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Fuel filter could be plugged...
