My new build in progress....
Old Jun 8, 2011 | 07:05 AM
one eyed willy's Avatar
one eyed willy
Default My new build in progress....
My 550hp motor let go back in February, broke the oil pump at the track. 8.8:1 JE piston/manley rods,stock heads/cams......precision 67mm billet turbo around 15 PSI.Ran 11.3....
NEW motor is:
Livernois 298 stroker
9.1:1
mahle pistons
manley rods
Comp 127300 cams
new lash adjusters
newfollowers
All ARP hardware
all new hot side
meth fogger kit
Billet oil pump
tr6060 6 speed
one eyed willy
Also "shaved" the engine bay, welded in all the holes....re-routed all the wiring, tucked the fuse block under the dash....moved the battery to the trunk.....all the wiring was done 2 weeks prior to the old motor letting loose, so i know its all functioning properly!
this is what the engine bay looked like after i did the wire tuck, before tearing it down for paint.....
Old Jun 8, 2011 | 07:06 AM
one eyed willy
new turbo bracket...
new downpipe getting roughed in....
have to get some power steering lines extended....
Old Jun 8, 2011 | 07:07 AM
one eyed willy
that about sums up the progress to this point!
whats left:
finish fabbing the hot side
get the hot side "jet hot" coated
alter the valve covers for the breather fittings (weld on some #10 bungs)
add breather cans - one to each side
order tr6060
order clutch
put the engine bay all back together
install motor & tranny
install meth kit
finish up some additional wiring
TUNING!!!!
Old Jun 8, 2011 | 08:01 AM
2005Redfire6's Avatar
2005Redfire6
Paul, looking forward to seeing it all put back together!
Old Jun 8, 2011 | 08:46 AM
Riptide's Avatar
Riptide
/jealousy
Old Jun 8, 2011 | 09:52 AM
Caution's Avatar
Caution
Sweet bro! Looks good so far.
Old Jun 8, 2011 | 10:21 AM
2007CalSpec's Avatar
2007CalSpec
Very cool! That's quite a project you've got there. How do you find the time to do all of this? Wish I had the time, energy, and money to do this kind of stuff.
Old Jun 8, 2011 | 11:35 AM
Alec's Avatar
Alec
Jesus christ
Old Jun 8, 2011 | 03:09 PM
VistaBlue's Avatar
VistaBlue
Originally Posted by Alec
Jesus christ
It's like you took the words I was mouthing as I went through the pictures and posted them.
