Old Oct 23, 2015, 03:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
Print Wikipost
Check engine: Throttle body problems
Old Jun 14, 2011 | 11:37 PM
omarV6's Avatar
omarV6
Default Check engine: Throttle body problems
ok, so brief history,
i have a 2005 mustang V6 Vert, about a year ago i installed a JLT Cold air intake. i installed it with the instructions from american muscle. (then the car started to give me problems so i removed the whole tune and CAI)
ever since i have been having problems when my car is on idle, (it would randomly turn off or struggle to stay on), now it finally threw a code out for me to find out the problem. i used my sct tuner to read the codes and i got this:
P2106:
Throttle actuator control system-forced limited power
P2135:
Throttle/ pedal position sensor/ switch a/b voltage correlation
any help on how to fix this would be very much appreciated!
Old Jun 15, 2011 | 12:29 AM
Alec's Avatar
Alec
Not sure if it's related or not but have you cleaned your TB recently? I cleaned mine this past weekend and was surprised how dirty it was. Caused my car to idle poorly and was much more responsive after being cleaned. Worth a shot
Old Jun 15, 2011 | 12:31 AM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Sounds like not only the Throttle body being dirty but maybe your MAF is dirty or bad.
When you clean your TB use CRC throttle body cleaner and when you clean the MAF use CRC MAF cleaner.
Our TB's have a protective coat and CRC makes the cleaner that will NOT take off the protective coating. SO use that stuff!
Old Jun 15, 2011 | 02:47 AM
omarV6's Avatar
omarV6
sounds like i have some cleaning to do!
is there a tutorial on how i can remove parts and clean it? cause knowing me, id probably F something up and make it worse.
Old Jun 15, 2011 | 06:53 AM
Nuke's Avatar
Nuke
Depending on how bad the TB is, you can simply use a suitable TB cleaner (to avoid damaging the coating on our TB's) and wipe with a lint-free rag w/o removing it. OR, remove it and do a thorough cleaning. As long as you're gentle you should be able to re-use the gasket. As far as the MAF, I prefer to give it a good spray w/o any other physical agitation. Some folks will use a soft toothbrush and very gentle scrubbing but the MAF is pretty sensitive and IMO a good dousing is all that's needed.
Hopefully the TB and/or MAF is your problem but based on the codes you listed, I wouldn't rule out a bad sensor.
Old Jun 15, 2011 | 08:48 PM
omarV6's Avatar
omarV6
if i go by cleaning the Tbody and the code is still on, what are my options? new TB/ sensor? are these expensive?
i saw the TB on AM and its like 400, not bad for the aftermarket performance, i might actually do this...
i wouldnt mind installing new performance parts...
but how bad is installation? im a novice
Old Jun 15, 2011 | 09:33 PM
Nuke's Avatar
Nuke
Originally Posted by omarV6
...i saw the TB on AM and its like 400, not bad for the aftermarket performance, i might actually do this...
Aftermarket TB's do nothing for you unless you're NA but heavily modified for some heavy breathing (cams, LT's, heads, etc). Ignore the moronic advertising.
I still think you have a bad sensor; probably TPS.
Old Jun 16, 2011 | 02:54 AM
Shadow7874's Avatar
Shadow7874
Removing the stock TB is as simple as 4 bolts so im assuming an aftermarket one is quite simple. Whether or not it is useful i cannot say
Old Jun 17, 2011 | 02:17 AM
omarV6's Avatar
omarV6
would you reccomend for me to buy a new TB sensor? i did touch it a few times and kind of mistreated it a year ago when i installed the intake, but idk why it would take a year to finally throw up some codes...
also, is it safe to drive my car around?
i drive like 17 miles to and from work every day...would you guys reccomend me not drive it or can i still do so?
Old Jun 17, 2011 | 06:14 AM
2005Redfire6's Avatar
2005Redfire6
Omar, since you have a 2005 it will be a little more difficult to remove your throttle body since the 2005 V6's throttle body is heated with coolant. Here is a write up I have on how to remove the throttle body and bypass the throttle body coolant at the same time, while it is off you can clean it!
https://mustangforums.com/forum/v6-s...nt-bypass.html
