Old Oct 23, 2015, 03:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
Print Wikipost
Check engine: Throttle body problems
Old Jun 17, 2011 | 01:46 PM
omarV6's Avatar
omarV6
Originally Posted by 2005Redfire6
Omar, since you have a 2005 it will be a little more difficult to remove your throttle body since the 2005 V6's throttle body is heated with coolant. Here is a write up I have on how to remove the throttle body and bypass the throttle body coolant at the same time, while it is off you can clean it!
https://mustangforums.com/forum/v6-s...nt-bypass.html
so the benefits of this would be no more heated TB? (this is quite interesting)
Another question though, once i clean the TB (and if thats the problem) will the engine light turn off? so i can know i did a job well done? lol
and idk if i can still drive my car to work? anybody know if its ok to drive?
Old Jun 17, 2011 | 01:55 PM
2005Redfire6's Avatar
2005Redfire6
Well if that is your problem and you clean it I don't think the engine light will turn off without a battery/ecu reset.
Old Jun 18, 2011 | 10:45 AM
157dB's Avatar
157dB
Cut & Paste Expert
OK.
A year ago when you were messing around and
treating the sensors rough, was the battery disconnected or live?
If disconnected, did you follow the battery removal instructions
in the owners manual about the adaptive learning relearning procedure?
Did you recalibrate the gas pedal assembly?
http://iihs.net/fsm/?dir=191&viewfile=Throttle Body.pdf
As for the codes, they are telling you whats wrong...
http://iihs.net/fsm/?dir=10&viewfile...scriptions.pdf
Ford lays out the procedure to troubleshoot codes...
Follow the procedures and quit the guessing game.
I would suspect a loose connector on the gas pedal
or a worn out 05 gas pedal assembly. The calibration
of the gas pedal will eliminate this guessing.
As for the ThrottleBody code, this can be caused from
an overly excessive dirty TB bore from bad rings
and oil getting thru the PVC tube. An air/oil
seperator can determine the amount of blow by
you have from the oil control rings on the pistons.
Once again, its an 05 with ?how many miles? on it?
Codes must be reset with a code reader.
You are pulling these codes out of the PCM ?how?
If you can read them, you can reset them?
p.p. do the heated TB by-pass mod.
eBay sells the kit. Its just a hose and two hose clamps.
Here is some good reading for ya...
ITEM # 10
jpplaw
Mar 19, 2025 08:53 AM
djbigskrilla
Sep 20, 2022 01:04 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
stanngg
Aug 12, 2015 03:43 PM
