threw 2 codes
Old Jun 16, 2011 | 07:41 AM
shad2009's Avatar
shad2009
Default threw 2 codes
hey guys,
i just got the jlt intake and tune combo from AM and right now im running the 87 street tune until the 87 drains out and i load the 93...i drove around last night and everything was fine...then the check engine light came on, i read the DTC's and i got a lean code (forget exactly the code with (b2) in it) then i cleared it and the engine light went away...then later on i went to go grab a bite to eat and the engine light came back on with a different code P0171 (b1) saying the system was too lean
a friend of mine suggested i clean the MAF sensor or it might be a tune issue and i need to call Bama...what do you guys suggest???
Old Jun 16, 2011 | 09:12 AM
Nuke's Avatar
Nuke
Check all of your hose clamps. If you're not sucking some extra air in from a leak, then call AM/Bama. Sounds like a tune tweak if the hardware is set up right.
Old Jun 16, 2011 | 10:14 AM
shad2009's Avatar
shad2009
thanks nuke, but i think i found the problem...on the underside of the intake elbow, there's a crease that you can see inside of...so i'm gettin alot of extra air lol
Old Jun 16, 2011 | 11:22 AM
Nuke's Avatar
Nuke
Originally Posted by shad2009
...a crease that you can see inside of...so i'm gettin alot of extra air lol
Yep. You're sucking extra air as I had mentioned.
Is that due to damage? Manufacturing defect? Installation problem?
Old Jun 16, 2011 | 12:02 PM
shad2009's Avatar
shad2009
more than likely an install problem...i was struggling to do this by myself lol...it looks like the intake elbow isn't looked on the throttle body, so when i tightened the clamp, it didn't do squat but leave the gap
Old Jun 16, 2011 | 12:14 PM
Nuke's Avatar
Nuke
Cool. Glad you found the issue. Enjoy the additional power. I was going to recommend that you run the custom 87 tune to get a feel for it's characteristics as compared to the other tunes but you're there already. Try to take a "spirited" drive on the 87 immediatley prior to filling up with the higher octane. Be sure that, before you repeat that spirited drive, that you log about 10-20 miles to clear the remaining 87 out of the fuel lines.
Old Jun 16, 2011 | 12:18 PM
shad2009's Avatar
shad2009
i have about a 1/4 tank left, maybe a little less...going to fill with 93 tonight and drive it to less the 3/4 then load up the 93 tune and sh*t myself when i put the pedal to the metal haha
Old Jun 16, 2011 | 12:25 PM
PSUSkier's Avatar
PSUSkier
I'd recommend you wait to fill up until you're basically running on fumes. The first time I played with tunes I loaded up the 93 when I had just over an 1/8 of a tank left of 87 and I had some detonation... I begrudgingly went back to stock and on the next fill up it was just fine.
Old Jun 16, 2011 | 12:31 PM
Nuke's Avatar
Nuke
Octane can vary from station to station and from delivery to delivery at each station. Getting a "bad" tank of fuel (lower than advertised octane) is a lot more common than one might think. The average driver never notices it but those of us tuned for it and those of us super-sensitive to the slightest hicup on our engines WILL notice.
Old Jun 16, 2011 | 01:37 PM
shad2009's Avatar
shad2009
that's what i'm doing...it's almost on E so i'm gonna fill with 93 and run it passed 3/4
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
