Oil Temp Sensor bypass?
Old Jun 20, 2011 | 01:48 PM
adidasUNT8's Avatar
adidasUNT8
Default Oil Temp Sensor bypass?
Hey guys. I just completed an engine swap on my mustang about a week ago, which was a nice experience. The new engine is still the 4.6 but with forged rods, pistons, crank, etc. It also has a Moroso oil pan which unfortunately has different threads for the oil temperature sensor to go in. I am constantly getting the P0198 code thrown now for oil high temperature. I am wondering if there is a way to bypass this. A friend of mine said you can get a wire and connect both ends making it a closed loop and it will not trip the code. I've heard some people say that you need to put some size of a resistor in there as well. Any help would be greatly appreciated!
Thank you,
Danny
Old Jun 22, 2011 | 08:29 AM
adidasUNT8's Avatar
adidasUNT8
Bump*
Old Jun 23, 2011 | 11:50 AM
157dB's Avatar
157dB
Cut & Paste Expert
Install the actual OEM sensor but dont physically insert it
into theoil pan and it will report ambient temps to the PCM.
Or measure the internal resistance of the sensor and insert
the proper value resistor between the two wires.
Whats evers yous dooooos dooooos, DONT connect the two wires together.
This will burn up the current loop in the PCM.
Old Jun 23, 2011 | 05:53 PM
otbiker's Avatar
otbiker
If you're going to do the resistor trick, which I recommend, place the element end of the sensor in hot water, maybe 150 degrees. Measure the resistance across the leads and get a resistor of that value. You may have to use a variable resistor to dial it in correctly.
Don't know if the ECM changes any parameters dependent on oil temp. Just a warning???
Old Jun 24, 2011 | 11:10 AM
157dB's Avatar
157dB
Cut & Paste Expert
It probably references it with the CTS and
if the corrolation is not correct, it could
throw a bad sensor code...
Old Jun 24, 2011 | 12:47 PM
adidasUNT8's Avatar
adidasUNT8
Hey guys i really appreciate the feedback. I guys i'll end up buying the oil temp sensor from Ford for $50. I believe mine is bad at this point as the sensor actually spins all the way around. From what I've been told it isn't supposed to spin all the way around. Is there any other place to get these oil temp sensors? Autozone doesn't carry them...
Old Jun 25, 2011 | 08:55 AM
157dB's Avatar
157dB
Cut & Paste Expert
gET THE fORD pART # AND HEAD ON OVER TO THE aDVANCED aUTO pARTS WEBSITE.
fricken caps lock.
With the Ford Part #, the WWW is your store.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
wraith777
Sep 28, 2015 10:49 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
