Center Dash Jack Not Working
Old Jul 10, 2011 | 05:51 PM
AzPete's Avatar
AzPete
First....how are you getting "power" from the neg. wire for LED's?
If the power/center button of the acc. plug is bad, then you need to remove the acc. plug to examine the actual center pin. I have seen these melt into the back of the unit and not function.
Have you used a meter to verify that there is no power in the plug? Also check power in the wire from the back side.
If you take shortcuts in wiring even for LED's, it is still a loose 12 volt connection that can come loose and short out or just be a loose fit and cause heat due to resistance. Either can be serious problems.
Old Jul 10, 2011 | 06:32 PM
Nuke's Avatar
Nuke
Old Jul 15, 2011 | 11:42 AM
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by hawkeye18
If you're as good at electrical wiring as you are at chemical engineering, then I think I see what the problem is.
+1
Throw a harness at it and see if the problem goes away....
Diode Dynamics
28
May 26, 2022 12:02 PM
Boostaddict
Lethal Performance
Sep 15, 2015 04:17 PM
AMWill
AmericanMuscle.com
26
Sep 8, 2015 01:32 PM
Boostaddict
Lethal Performance
Aug 13, 2015 01:57 PM
Bryan@Autogeek
Aug 5, 2015 12:33 PM
