Center Dash Jack Not Working
Well my center dash jack doesn't work. The negative terminal does (I use it to power some LEDs -) but the positive just doesn't work at all.
The center dash jack was already broken when I connected the LEDs
Do I just need a new wiring harness?
Di ya ref the OM and checka da fuse in da BEC unda tha hooood?
Otherwise, yes its dealership time and a whole new harness...
Is it worth $1000 bucks to get power out of this "jack"?
Maybe just ride it out until the vert arrives with a working power "jack".
^That, never get your ground from the negative on your power sockets/input auxiliary.
When I installed my interior lighting, I used one of fords grounds with solderless terminals. That method usually stands the test of time, and keeps from possibly crossing/shorting out wires.
Have you tried following your power wire down? Maybe a loose connection? Double check you ground and fuse.
My LEDs are just a wire lead crammed into the harness.
I can do wiring. Can't I just buy the harness and splice it in?
The vert will have the wrong color scheme. I need the jack now because I have a blue bulb thing to plug in...
Its just an LED strip. I was in a rush and I popped it in instead of doing the proper splicing that I did with the radio.
