Altitude Sickness...
Old Jul 14, 2011 | 02:00 AM
Thrashard340's Avatar
Thrashard340
Default Altitude Sickness...
I live at sea level. I went to Lake Tahoe this past weekend (6,000+ ft). This was the second time in three years I went there. After 3,000+ feet, I lose a lot of power at low RPM's. There's a wicked bog until 2,500 RPM's and then the motor comes alive. I did a search on this forum and it seems this is the type of performance expected at high altitudes. I saw a few S197's in town. For those of you who live at these altitudes, I don't know how you guys put up with it. More power to you. I spent 3 days in Tahoe and was already sick of driving in that town.
Old Jul 14, 2011 | 06:09 AM
2005Redfire6's Avatar
2005Redfire6
I would imagine the loss of power was terrible, then again if you live up there I am sure your car is tuned for that!
Old Jul 14, 2011 | 06:14 AM
2007bluestang's Avatar
2007bluestang
I agree with the guy who never pmed me back...jerk
Old Jul 14, 2011 | 06:55 AM
Lifter583's Avatar
Lifter583
Damn physics...less oxygen at higher elevations...less fuel can be added...less power...do a search on "air density" very informative on the huge effects of atmospheric conditions on a car...
Old Jul 14, 2011 | 07:20 AM
Nuke's Avatar
Nuke
The engine can be tuned for those conditions. It's only an issue for us sea-level lubbers...
Old Jul 14, 2011 | 07:32 AM
highline's Avatar
highline
as said, yes, if you live there your tune would be different than at sea level...where you go to? Have a house at Zephyr Cove...Nice there
Old Jul 14, 2011 | 08:50 AM
Riptide's Avatar
Riptide
There is only so much they can do to "fix" this with a tune. Less oxygen in the air means less power period. And keep in mind that MANY people use mail order tunes as well and are not dyno tuned or given any type of special high altitude mail order tune.
You want to "fix" this then you need to put a blower on the car or start using a bottle. Either that or move.
On the bright side it effects everybody else the same so the playing field is leveled. People that run 13s in the 1/4 mile NA at sea level are all going to be down by nearly a full second at 5000+ feet. It's all relative..
Old Jul 14, 2011 | 11:14 AM
Mishri's Avatar
Mishri
Mish-ogynist
hah yeah, check my sig for what altitude does to you everything feels relative though. I really want to take my car down to sea level, see how it feels or run it at a drag strip if possible.
like riptide said, n2o or a lot of boost can negate the effects of altitude though. there are some formulas to determine how much boost you need to run for it to no longer have an effect. like the air pressure at sea level is 32 psi and at 6000' DA it's 17 psi and compression ratio in your car is 11:1 and you are running 36psi of boost and you stick in a forumala i posted somewhere and it comes out to not needing a DA correction As far as I know that is mostly theory, I haven't seen proven real world results, maybe someone who has done a lot of travelling with a heavily modded dragster can say.
Old Jul 14, 2011 | 01:19 PM
2011Kona3.7L's Avatar
2011Kona3.7L
Watch Top Gear (BBC) S14E06 if you want to see the extreme case of this.
Old Jul 14, 2011 | 01:42 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Cars sold in various states like Colorado will have a 'High Altitude' tune. In the past it would make a difference in the emissions devices too.
