Clicking from drivers side dash
09 GT/CA, I have a loud clicking noise coming from the dash when I go to start the engine. I've read a number of different things, A/C relay being one, and the blend door actuator, is sounding most likely. I was just wondering if there's a TSB or recall on this issue that anyone knows of? I just picked this car up last week, "God I hope this is it for the bugs"
No hesitation. Just the clicking for about 5 seconds and it stops. Its loud though, totally sounds like a gear clicking. everything was fine the other day and now it does it every time I get in the car. Other than that everything is perfect.
Hi frodin1,
I recommend that your vehicle be inspected by your local dealer to determine the cause of your clicking. With this being such a new-to-you Mustang, you definitely want to make sure everything is functioning correctly. Please let me know if I can help in any way!
~Natasha
~Natasha
And no, I don't think there's a TSB on it, it happens, but it's not as common like other issues.
It is the Blend door, If I shut the car off with the fan running, that's when it does it. Shut the fan off prior to shutting the motor down, no issues. I am still under warranty till next year. So its all good. I'm going to go through it with a fine tooth comb to make sure there's nothing else! Anything specific I should look for that common in the Mustangs? If they cut down on the plastic , maybe they wouldn't have so many issues.
The only others I can really think of are:
a. The angle of our wind-shield makes susceptibility to small rocks an issue. I've replaced 2 now from owning 2 S197's in 4 years.
b. Rattling from various bits from even the sub-par stock audio systems, specifically window control housings, plastic rings on shaker 500 door subs, etc.. All that crap I fixed on my current mustang, but it annoyed the crap outta me, not something they will normally fix as warranty work, and in most cases not something I'd want them to try to as they'd probably scratch/scuff-up and leave other things loose to rattle later.
c. Manual transmission - synchronizers, I still get a cringe-making grind from 2nd into 3rd the first one or two shifts in near freezing temps.
You can click on the mustang TSB link at the upper right of the page if you'd like to go through the official ones from 05-09 which might pertain to you.
