Lumbar seat faliure
Lumbar seat faliure
So I just bought my 06 Mustang a month ago and so far I love it! But I tried to adjust the lumbar support in the seat and it got stuck all the way down. Now when you press the button all it does is make a click click click sound and doesn't move at all. After doing some research it sounds like the gear is stripped in the motor. My question is since I bought a warranty from the chevy dealership I bought it at, will they fix it? Also, if I want to just do it myself where can I get the parts from and how hard is it to do? thanks
Mine broke as well, but it was covered by warranty. Apparently, it is a pretty easy fix (took an hour according to the work order), but you have to be careful if you have side airbags. There is a de-powering procedure to follow before you pull the seat.
It's an easy fix if you are mechanically inclined and are used to taking care of things yourself. I did mine in a couple of hours on a Saturday afternoon.
Sorry to dredge up an old thread, but is there a source for the drive gears for the lumbar support motor?
I bought a '07 ragtop for my daughter, and among other things, the lumbar adjustment didn't. I found the spring had broken, so I used the 'hose clamp' repair method. But when I put it back together, the problem remained.
So I took the top off the drive motor, and I found at least a dozen pieces of nylon planetary gears.
Until I find a solution, I rigged the lumbar 'pad' with two big zipties to tension it. It may stay that way...
GT350 S550 Tech
09-29-2015 03:29 PM
