Rust on stock brake rotors?
After driving in some water/rain/blah blah etc, I'll come back to my car after a bit, and my brake rotors will be covered in rust.
Of course it goes away when I use the brakes, but it's just unattractive to walk out to.
Is there anything I can do (Aside from getting new rotors), to keep them from getting rusty when wet?
m not sure if you know or not that its completely normal for disc brakes to rust. Best thing to do in my opinion is to drive the car. Some people will use oil on show car rotors but that of course affects your ability to brake. Most people just deal with it, as anyone worthy of judging your car wont think twice about it. As far as the non-friction portions of your rotor, you can look into high-temp paints.
That's just cast iron for you! I washed my car the other day (like the third time this year...eek) and it wasn't two minutes after getting the rotors wet before they had rusted. Last time I replaced my front rotors I did get some that have the paint on the non-braking surfaces and that seems to be holding up reasonably well.
Nothing you can do about it - even without rain, just a high humidity day - will cause rust spots to show up. It isn't limited to Mustangs or unique to them, you will see it on virtually any disc brake rotor.
You can buy ST ST rotors. They look pretty but I hear they don't hold up well under hard braking due to not being able to dissipate heat as well.
As far as the rust, it disappears after the first application of the brakes anyway.
