shifting an Auto
Old Sep 7, 2011 | 03:09 PM
07mark's Avatar
07mark
If you like shifting an auto manually, then maybe contact TCI and see if they are planning on making a rachet shifter for the new 5.0's. I plan on buying the shifter for the 05-09's later this year.
Old Sep 14, 2011 | 01:18 PM
BKRmustangv6's Avatar
BKRmustangv6
Originally Posted by MustangFirstCar
I actually use the 1-2-3-D (od off) when driving around town. Never caused any problems yet.
What would be the upside to doing it with the od off instead of on?
Old Sep 14, 2011 | 01:27 PM
MustangFirstCar's Avatar
MustangFirstCar
It's more like a 4spd. The point of shifting manually like that anyways is to have more control over the car. To me, having it automatically shift from 4-5 once I put it in D just kind of eliminates that point.
Old Sep 14, 2011 | 01:54 PM
grabber blue gt's Avatar
grabber blue gt
+1 ... Whenever I shift my auto manually I always turn o/d off. It basically almost goes into 5th right away if you have the o/d on and put it in D from 3
Old Sep 14, 2011 | 02:45 PM
BKRmustangv6
Ok so od off. Go from 1.2.3.4. Then once in 4th, turn the od on and it will go into 5th right then?
Old Sep 14, 2011 | 03:43 PM
jrny99's Avatar
jrny99
I'm so glad i bought a stick
Old Sep 15, 2011 | 01:09 PM
MustangFirstCar
Correct
Old Sep 15, 2011 | 05:29 PM
mayo's Avatar
mayo
Correct
What the hell transmission do you guys have???lol
Must be different with mine...
First off, there is no 4th...its D. When you shift to D with or without o/d engaged, it's in 4th headed for 5th. The time it takes 5th to engage is all dependant on your shift points, but if you go to D it will go to 5th eventually. Once the rpm and throttle input correspond it will then go to o/d (when on).
Manually shifting an auto will produce more internal heat in the transmission as opposed to leaving it in D, keep that in mind. For that reason, I wouldn't just drive around all night manually shifting.
The TCI is a great bet...love mine!
Old Sep 15, 2011 | 05:45 PM
kput's Avatar
kput
I'm pretty sure that turning overdrive off makes it to where you will not go into 5th gear. So drive would put it in 4th. Turning overdrive off, 5th
Old Sep 15, 2011 | 06:59 PM
JIM5.0's Avatar
JIM5.0
Originally Posted by Al19067
Whats up guys i have a 2012 gt Auto and when im doing around 40 i like shifting it down to 3 to hear the exhaust(i have roush exhaust), will this hurt the tranny? Thanks
Why do you have to shift it yourself? Just floor it and it will automatically downshift by itself so you can hear that oh so bad *** sound of your exhaust!
