Can I put front calipers and rotors on the rear as well?
I found some front calipers and rotors for cheap, and I was wondering if A) can I put them on the back? B) Would it make any difference at all? Thanks!
No, you can't. Fronts are dual piston calipers, the rears are single.... And plus I doubt it would do much mainly cause most of your braking force comes from the front (hence the bigger rotors).
I think it would be a great mod project. Of course, get the front calipers and brackets and rotors. But you will have to fab some stuff to bOlt the brackets onto. And it will have to be factory precision work or stuff will not line up correctly.
