Which tires to go on these rims?
With the 18's being dedicated to winter use, Blizzaks in 255/45 are probably going to be your best bet. Dropping the inch in wheel diameter typically calls for a 5 higher profile number, so you'll still be sitting at very close to the same ride height as on your 19's.
Snake - Michelin used to make TRX tires in really odd sizes, and there actually was a 240/45 . . . a 240/45-ZR415 to be exact (metric wheel diameter).
Norm
Norm
I'm a fat tire guy myself though.
Nothing looks as good as a nice fat back tire.
We have 18x9.5 and my next back tire will be a 305.
The stance just looks WICKED!
Your choice of wheel has limited you in tire choice. Being 9 1/2 in wide, you can't monut a thin tire, and the 255/45-18's are probably wider than you want for winter driving. I have those same wheels with 255/45-18 Hankook v12's all around and love them, but then again I'm in south florida where a cold day is maybe high 60's........
305/45's will work OK-ish on a 9.5" wide rims.
305/40's and 305/35's would be slightly squeezed down if you put them on 9.5" wheels (they really need to be on 10" - 12" wide wheels). Not the best situation for a couple of reasons.
Norm
