Rattle in the Lower End of Gears
Recently I've been having a rattle that I can't seem to identify.
It only occurs in the lower end of the gears (mainly 1st and 2nd). It's really noticeable with the windows down, and it sounds like a high frequency metallic rattle.
Kind of hard to explain, but the worst it gets is when the gear bottoms out...you know that point where you can feel the gear kind of bounce along at the lower limits of it's speed...the rattle is worst at that point, and then fades out as RPMs increase.
Immediate thought when I heard it was exhaust...but I'm not really sure. I have aftermarket exhaust so that could definitely be it, but the frequency of the rattle leads me to think something else...a lighter piece of metal hitting up against something so that it can move really quickly...
Just recently I started getting a new noise too...it's like a low "whump" sound that increases in frequency with speed and decreases as I slow down. That leads me to think it has to do with tire rotations...something rubbing there. I've had something similar, but it turned out to be a little twig stuck up in my rocker panel hitting the tire, but I could pinpoint the location of that one (front right wheel well). This one sounds like it is behind me, but I can't pinpoint it exactly.
I know this is vague, but I was just looking for possibilities so I can check them out.
Thanks,
HT
Thanks,
HT
What RPM range is that metallic rattle in? I and others have had a metallic rattle. Mine was around 800-1200 RPM and turned out to be the axleback clamps needing a little more torquing. For some others, it was the heat shields. And for some others, it was axle-hanger-to-frame contact.
Wow, didn't notice that this thread had any responses...I'll check the range for ya'll. I am positive it's on the lower end, but not sure on the exact RPMs. I got under the car and beat on the exhaust pipes a bit to try and get the rattle to replicate, but I got nothing.
I am pretty certain it isn't the hangers. Heat shield and or clamps could be the culprit. It does, however, sound like a sheet of metal is one of the components...which is what threw me off a bit.
For what it's worth I had a similiar noise in my 97 Cobra. It was very noticeable when going slower under load like up a hill. I replaced the clutch a few months back and the noise is gone. We looked at the old clutch and could not see anything wrong. All I know is the noise is gone!!
