Removal Door trim Panel
I've got PDF file of "removal and installation" for 05'stang's door trim panel .
But I am not clear how to remove "#14527/14528 Window control switch housing" and "#6322620/6322621 interior door handle cover" .
Can you give any Tips for removaling thoese parts ?
Thank you
Thank you
the window control switch housing just pops off and you have to unplug the power connections. then you have to pull off the rest of that piece it was snapped to by hand and there is another screw behind that.
you dont remove the interior door handle cover. there is a thin plate of plastic behind the door handle that you have to pry out with a knife. it just kind of sits in there secured by one side (really easy)...and there is another screw behind that little plate.
Thanks for your information,
But I still can't take off the window control switch housing.
I found there are 2 segments on this parts (please see attached pics, I marked red area and blue area)
Do you mean First take upper plate (red area) ? then after unpluging ,take the rest of parts (blue) ??
Which point did you insert the lever tools for pops off ?
Sorry for asking again ,but all for thiis is fear of damaging.
JJ
[IMG]local://upfiles/16362/C0C959BEEB3A481BA79F5D62F3CD74EB.jpg[/IMG]
JJ
These pics are for someone who are interested in this treat for the future.
Thanks Crutchfield.com . their support is excelent !
JJ
[IMG]local://upfiles/16362/1A48F97485394E16BC9FEAEAFF060C09.jpg[/IMG]
[IMG]local://upfiles/16362/0A180C2F90C44063B86CF67AA6651B2B.jpg[/IMG]
[IMG]local://upfiles/16362/E6630D66CF98482AB820AD2B7EEAA4ED.jpg[/IMG]
[IMG]local://upfiles/16362/03FE65EC26314CFFBDB96C715D739333.jpg[/IMG]
JJ
ORIGINAL: allisponygirl
Can anyone find this pdf i can't and need it bad.
breaking
Oct 2, 2015 01:27 PM
