Replace 2012 base steering wheel with 2007 leather steering wheel
Has anyone replaced their 2011 or 2012 base steering wheel with a leather and silver wheel from a 2005+ Mustang? Can you explain if you had to swap out the cruise switches to get the proper connections for the 2012?
Hmm, I just looked at my stock rubber wheel. It doesnt look to come apart for easy removal of the switches like the leather wheel does. I might have to rethink this project, I was hoping I could go back to the rubber wheel if need be, but this would be a one way trip as I would have to cut the button panels out.
The 05-09 steering wheels have the two screws on either side of the wheel, and one center bolt that gets torqued down to about 41ft. lbs.
The old ones also have 2 wires leading into the airbag assembly, and one clip wire for the cruise control. Assuming the harnesses for these are the same in the 2011+ (which I doubt they are) then it would be a direct swap.
For you 2011+ owners, here is a guide to changing the 05-09 wheels below, I recommend looking at the pics to tell if your wiring harnesses are the same or if they need to be swapped out.
Here is the link mentioned above: https://mustangforums.com/forum/2005...-for-s197.html
NOTE: I am told these bolts are torqued down to a level of "deformation" or something like that, if you want to be extra safe/precautions, I would suggest you get new bolts to go with the steering wheel swap as the old bolts might be slightly warped.
