Torque specs
Old Dec 13, 2011 | 05:47 PM
outceltj's Avatar
outceltj
Default Torque specs
I was just wondering how important are these values. Im gonna do a whole brake upgrade package and was wondering how important it is to have everything torque to spec. Im asking b/c I dont have a torque wrench.
Old Dec 13, 2011 | 05:50 PM
aaquib1992's Avatar
aaquib1992
Not sure on the torque specs for a brake kit, but my guess is that even if everything is a little over torqued it shouldn't hurt anything. What I used to do with spark plugs on my old car was get a good feel for how tight they were when I took them out the first time, then just tighten them back to that "feel" lol.
Also I just ordered a new wrench off amazon for $30. It's a neiko brand (cheapo) and has a range of 10-80ft. lbs. Not bad, and fairly accurate from the reviews. You should give it a whirl.
Old Dec 13, 2011 | 07:11 PM
americaniron's Avatar
americaniron
I didn't use a tq wrench when I swapped my brakes for the Brembos.
Old Dec 13, 2011 | 07:17 PM
Hack Job's Avatar
Hack Job
Craftsman Beam Torque Wrench, 3/8 in. Drive
On sale for $21.24
I'd be careful with fords 1 time bolts, TTY bolts and anything aluminum.
Old Dec 13, 2011 | 07:47 PM
bakerjd's Avatar
bakerjd
You're going to pay for an entire new brake system and you can't pony up for a torque wrench? lol...Get a craftsman, you'll be glad you did.
Old Dec 13, 2011 | 08:07 PM
outceltj's Avatar
outceltj
money isnt whats stopping me its just the face of how important it is. I mean even the wheels when u bolt them on are suppose to have a torque spec but I never follow that. So i was just curiouse from what others had to say
Old Dec 13, 2011 | 08:30 PM
JIM5.0's Avatar
JIM5.0
As particular as I am, I am extremely meticulous about the torque specs that the kits tell you to tighten the bolts, nuts, and screws down to.
Hell, when I change my oil, after I am done, a bust out a small toque wrench to tighten the plastic wind guard back on under the engine.
When it comes to brake, I personally think the torque specs are important so that your carriers are aligned correctly, the calipers are in proper position, and there is greatly reduced change of putting the wrong moment on the discs when you apply the brakes.
I do not know just what tolerances of twist perpendicular to the hub center line that the brake discs are designed to take, but being the meticulous guy I am, since I prefer not to put that tolerance to the test.
This is just me, it might be possible that the brakes can take more torque and no warping of the carriers or calipers will occur nor will the pistons apply the pads at the wrong angle to the discs, but I have no clue since I am not a professional brake mechanic.
Old Dec 13, 2011 | 08:34 PM
Hack Job's Avatar
Hack Job
Threaded Fasteners, Torque-to-Yield, and Torque-to-Angle
I would say the importance depends on what it is your tightening down.
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
LivingInThePast
Sep 16, 2015 12:20 PM
