ac problems
Old Dec 18, 2011 | 12:08 PM
ryancolby's Avatar
ryancolby
Default ac problems
So a passenger in my car spilled a soda all over my ac/radio bezel and i cleaned it up as much as i oculd but now the heat is not working..Anybody have any ideas that would help fix it?
Old Dec 18, 2011 | 12:34 PM
Lethaldosage423's Avatar
Lethaldosage423
When you turn the temp. **** from cold to hot do you hear anything?
Check the wiring behind the dial and see if their is power.
If there is power then then your "Blend Door Actuator" may be fried.
This actuator blocks off the heater core so you get cold air. and when you turn the dial to hot, it opens the door.
if its not getting power. your switch may be bad
do any of the other ***** work? Fan speed or the air directional ****?
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
