When to Replace Shocks and Struts
Old Dec 26, 2011 | 04:23 PM
rlarroque's Avatar
rlarroque
Default When to Replace Shocks and Struts
Hello!
I have a 2006 V6 Mustand and I have about 80k miles on it. I wanted to know what your guys' experience has been on shocks and struts. My tired are wearing on the inside so that makes me assume it's the shocks and struts starting to give out. If my assumption is correct I wanted to know what kind would be a good upgrade from the factory ones but won't break the piggy bank.
Thank you for your time!
Old Dec 26, 2011 | 04:29 PM
Goldenpony's Avatar
Goldenpony
Originally Posted by rlarroque
Hello!
If your tires are wearing on the inside, it's more likely an alignment issue. If you do decide to replace the shocks & struts, Koni STR.Ts are a great upgrade. Put them on & get a 1st class alignment.
Old Dec 26, 2011 | 04:31 PM
JimmyM's Avatar
JimmyM
I would recommend the Koni STR.T... decently priced with nothing but good reviews on quality
Old Dec 26, 2011 | 05:48 PM
Norm Peterson's Avatar
Norm Peterson
Inside shoulder could be exaggerated by struts that have lost much or most of their bump damping (the car overshoots on the downward motion, which briefly drives the cambers more negative than they should be and more than likely the toes will briefly go a tiny bit more 'out'. Neither effect is part of the recipe for long inside shoulder life.
Anyway, one way of telling when shocks and struts should be replaced is to ride in a similar car with new ones, jump right back into your car, and immediately drive the same route. If it feels like the car is moving around much more, it's time. BTW, the current 50k suggestion that one of the mfrs has been pitching lately isn't a bad guideline either.
One more vore for the STR.t Konis.
Norm
Old Dec 26, 2011 | 09:52 PM
bakerjd's Avatar
bakerjd
Call Sam Strano...he is THE MAN, period.
Old Dec 26, 2011 | 10:03 PM
MustangFirstCar's Avatar
MustangFirstCar
Yeah, Strano will hook you up man. He knows like, everything.
Old Dec 27, 2011 | 10:52 AM
onederful100's Avatar
onederful100
you should replace those weak strut mounts as well.
if you notice a bumpier ride, or the struts making noise, time to upgrage.
Old Dec 27, 2011 | 11:16 AM
jdmcbride's Avatar
jdmcbride
It also depends on how long you plan on keeping it. If you are going to trade at 100k, then it would not be a good idea, but if you plan on keeping it for another 50 - 80k, then yes.
Old Dec 27, 2011 | 12:46 PM
kevinmalec's Avatar
kevinmalec
You can go to a tire shop and get an alignment done. They will tell you how bad camber and toe is off and how it can be corrected. I had an alignment done once I lowered my car to make sure it wasn't out of spec.
5.0muscle
Jan 11, 2016 01:17 PM
MusicCity615
Sep 12, 2015 07:05 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Luke9222
Sep 4, 2015 06:46 AM
