Found Problem FINALLY
Old Dec 30, 2011 | 02:38 PM
mystangisblack's Avatar
mystangisblack
Talking Found Problem FINALLY
So I've been dealing with this squeak in my rear, right side wheel well area and for months I couldn't pinpoint the problem. Yesterday when I was washing my car I decided to spray every bolt around there with WD40. One by one I would spray, and then shake the car to see if it squeaked. I finally came to one that I sprayed and it finally didn't squeak. Now, what's the real problem and what can I do to prevent the squeak for good. A new bolt? Tighten it? Here's some pics of the bolt im talking about.
Old Dec 30, 2011 | 03:01 PM
wcgman's Avatar
wcgman
If Im not mistaken, that's a lower control arm. Chances are the bushing is making the noise. Given it's probably torqued to factory, I would not crank on it. You could get a replacement bushing, pull the bolt, grease the new bushing, put the bolt back in and torque it back to factory. But usually the bushings are sold as a set, so you might as well plan on pulling the lca off on both sides to replace the bushing...and if you're doing that, you might as well consider putting an aftermarket performance lca (which should come with new bushings!) on the car...It'll help eliminate wheel hop when you install 4.10s
Old Dec 30, 2011 | 05:54 PM
Lethaldosage423's Avatar
Lethaldosage423
Upgrade your lower control arms!!! Perfect oppertunity lol
I'm not sure if those bushings press out of you may have to buy the whole arm.
(with the front control arm bushings, if you want to replace them with factory ones, you have to replace the whole arm.)
Old Dec 30, 2011 | 07:07 PM
JimC's Avatar
Super Moderator
Just get the J&M HotPart lower control arms with the poly ball bushings and replace those. The rear end will feel a lot tighter than before, the poly ball bushing will let you take corners without binding, and the squeak will be gone.
Old Dec 30, 2011 | 08:27 PM
aaquib1992's Avatar
aaquib1992
For a quick fix I wouldn't use WD40, try going to the local walmart and getting some water proof spray on silicon and saturating the area where the bushing is with that.
That's what fixed my squeak, but a full fix (with some added benefit) are the new LCAs everyone is talking about, I'll get around to those sometime lol.
Old Dec 30, 2011 | 08:57 PM
defiance's Avatar
defiance
That's more than enough excuse to change out control arms! lol I have a squeak as well, maybe I should investigate to see if it is that bolt.
Old Dec 30, 2011 | 11:02 PM
legendlime05's Avatar
legendlime05
change em out for one that have a poly bushing, the poly bushing is a MUST. there not that expensive and the install is cake!
Old Dec 30, 2011 | 11:15 PM
05StangZz's Avatar
05StangZz
Yep what they said! I installed LCA's over the summer and what a difference!!
Install is pretty damn easy too!
mystangisblack
Thank you guys so much for the help. This is why I love being a part of this forum. I came into here knowing nothing about stangs and now I know a ton. Thanks again!
Old Dec 31, 2011 | 11:30 AM
incorrigible's Avatar
incorrigible
Get these
Use Toco Bills awesome write up to install.
Squirting silicon spray or WD40 is a temporary solution at best. It *will* start to squeak again in a month or two.
