Found Problem FINALLY
Old Dec 31, 2011 | 12:09 PM
05StangZz's Avatar
05StangZz
While you are at it, you may as well change the upper control arm and change out your differential fluid. Royal purple works well i hear but everyone has a preference. ;-)
Old Dec 31, 2011 | 12:10 PM
05StangZz's Avatar
05StangZz
Originally Posted by incorrigible
Get these
Use Toco Bills awesome write up to install.
Squirting silicon spray or WD40 is a temporary solution at best. It *will* start to squeak again in a month or two.
Those are pretty
Old Dec 31, 2011 | 12:24 PM
aaquib1992's Avatar
aaquib1992
Get these
Those actually look pretty awesome. But after about 4-5 months so far I haven't had the dreaded squeaks so he might luck out like I did lol. If you want to save money OP; I would suggest just removing the stock LCAs and grease the bushings, 1hr job tops and it saves you some money as these bushings came poorly greased (or not at all) from factory.
djbigskrilla
Sep 20, 2022 01:04 AM
Luclin999
Sep 7, 2015 11:33 PM
rocket22
Aug 28, 2015 07:08 PM
timeformiller44
Aug 26, 2015 12:03 PM
raven_ghostwolf
Aug 16, 2015 08:16 PM
