Sponsored by:
Sponsored by:
engine service at dealership
Old 01-05-2012, 04:45 PM
m5miler
m5miler's Avatar
Default engine service at dealership
i'm heading back to school on saturday and the service engine soon light popped on on my way home today. i haven't had my engine serviced since before the tune and my warranty is pretty much up. do i need to worry about them resetting the tune when they check the engine out? should i tell them i have the tune? i want to make sure everything goes like it should just so my car is up and running properly. thanks
m5miler is offline
Old 01-05-2012, 05:19 PM
rls82959
rls82959's Avatar
They might reflash the tune.
You're warranty is over, tell them NOT to mess with your tune.
Some stealers wouldn't care about the tune even under warranty. Some would.
rls82959 is offline
Old 01-05-2012, 06:23 PM
m5miler
m5miler's Avatar
oh ok. i'm going to check to see how much longer my warranty lasts, i wanna say its 30k cuz we bought the car used. if they reflashed it would i be able to upload my tune again from my hand held tuner?
m5miler is offline
Old 01-05-2012, 06:30 PM
BigDinTexas
BigDinTexas's Avatar
If you have the handheld tuner, why not use it to figure out what the code is before taking it to the dealer? I am presuming that you the "service engine soon" is the same as a check engine light... You might discover it is something as simple as the gas cap not being tightened completely.
Don
BigDinTexas is offline
Old 01-05-2012, 06:54 PM
m5miler
m5miler's Avatar
i went out and checked it. it said "p0340 camshaft position (cmp) A ckt (b1 or single sensor). car runs fine, but is this bad?
m5miler is offline
lawrencecar1
lawrencecar1's Avatar
Don
if not get a cheap code reader $20-30
lawrencecar1 is offline
Old 01-05-2012, 07:12 PM
m5miler
m5miler's Avatar
i used the hand held and the code i have above is what it said. any idea if this is something that can be easily fixed?
m5miler is offline
Old 01-05-2012, 07:15 PM
m5miler
m5miler's Avatar
well i read up on the code on google, and here is what i found.
http://www.obd-codes.com/p0340
is this something that could be fixed easily, or will the dealership need to fix it.
m5miler is offline
Old 01-05-2012, 07:23 PM
AzPete
AzPete's Avatar
Well, if you have the ability to check the position sensor, wiring, and pcm for which part is the problem, then yes it can be easily fixed.....otherwise, leave it to a dealer or repair shop.
Plus......if you have warranty, why not use it......
AzPete is offline
Old 01-05-2012, 07:28 PM
m5miler
m5miler's Avatar
alright cool. well i have no idea how to fix it lol and i don't want to attempt it and mess it up. the warranty is almost out i'm pretty sure, and i would tune my car back to stock to go to the dealer but my cai requires a tune, it stalled on me and my friend when we started the car up the first time after installing it before uploading the tune. what should i do?
m5miler is offline
Quick Reply: engine service at dealership
