Gear changes
Old Feb 8, 2012 | 08:44 PM
Runner's Avatar
Runner
Default Gear changes
HELP!
am having problems re-calibrating speedometer on my 08 GT.
Tires were changed from 17 to 18's. when re-calibrated, speedometer still off,
checked with another vehicle and GPS, when running 70 in mercury, GT shows 90 on speedometer.
if gear box has been changed to either 3.73 or 3.55, would this account for difference.
thanks for any help figuring this out. what's the cure.
Runner
Old Feb 8, 2012 | 08:49 PM
MurrietaStang's Avatar
MurrietaStang
Yes, changing gears will affect that. I've always used a tuner to set the gear ratio and tire revs per mile. I'm not sure how you'd do it without the tuner.
Old Feb 8, 2012 | 08:50 PM
AzPete's Avatar
AzPete
Rim size makes no difference in speedo....it is the tire diameter which can be the same for various size wheels. Also, yes, the rear end gearing will change things too.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
