Need help
Old Mar 21, 2012 | 05:21 PM
Brian1968's Avatar
Brian1968
Default Need help
Ok so I take my 05 out for the first time today I turn left and my turn signal is blinking fast.So I think burnt out bulb but after checking the bulbs are fine.I look at fuses don't see any that are broken. From what I can see it looks like this one bulb is fine nice and bright the next is a little duller and the last is very dull.If I just have the DRL on it looks fine. I don't know what else to look for.
Old Mar 21, 2012 | 05:23 PM
ironh19's Avatar
ironh19
check the blinker fluid you might be low. or replace start replacing bulbs because one of them maybe about to go out. and its causing a draw somewhere.
Old Mar 21, 2012 | 06:28 PM
Nuke's Avatar
Nuke
If the bulbs are good, the next thing I'd do is clean the socket contacts AND the contacts on the wiring harness plug.
Old Mar 22, 2012 | 07:11 AM
wcgman's Avatar
wcgman
[QUOTE=ironh19;7883229]check the blinker fluid you might be low. QUOTE]
I think Pep Boys has a special on gallon size blinker fluid this week too.
Old Mar 22, 2012 | 02:13 PM
ironh19's Avatar
ironh19
[QUOTE=wcgman;7883975]
damn and the nearest one by me is all the way in pensacola.
Old Mar 22, 2012 | 02:22 PM
kevinmalec's Avatar
kevinmalec
That's odd....you check all 6 bulbs on the rear and the 2 front turn signals?
I had the same issue, however it was the turn signal bulb that burnt out in the tail light.
Old Mar 22, 2012 | 03:31 PM
AzPete's Avatar
AzPete
Did you actually check the bulbs when they were flashing as a turn signal? Compare left to right.... Have seen many that thought because the tail lights work, the bulbs are fine......or change the fluid as suggested.
Old Mar 22, 2012 | 06:03 PM
Brian1968's Avatar
Brian1968
Got it.. the front bulb keeps falling out fixed the socket contacts now it good and tight.Now i have to figure out why my ABS light is staying on??? OH and yes the fluid is nice and full..thanks
Old Mar 22, 2012 | 09:42 PM
ironh19's Avatar
ironh19
faulty abs sensor, have you been inside your wheels lately? doing brake jobs and such?
Old Mar 23, 2012 | 02:35 PM
Brian1968's Avatar
Brian1968
did new rotors and pads at the end of last fall.
