What Next?
Old Apr 14, 2012 | 03:53 PM
06stangia's Avatar
06stangia
Default What Next?
Looking for a little more power car has SCT tune, electric water pump, CAI, Ford racing cat backs, and short shifter. So what should be the next mod?
Old Apr 14, 2012 | 04:03 PM
baddog671's Avatar
baddog671
Cams+LT
Old Apr 14, 2012 | 04:06 PM
Shift's Avatar
Shift
Are you trying to keep it N/A? If so, what he said ^ Camshafts, Engine Port Cylinder Heads, Headers, etc.
Old Apr 14, 2012 | 04:27 PM
06stangia's Avatar
06stangia
It has the shacker hood so if i went to a s/c i would need a new hood and s/c too $. What about underdrive pulley set.
Old Apr 14, 2012 | 04:29 PM
06stangia's Avatar
06stangia
Sorry what is LT?
Old Apr 14, 2012 | 04:30 PM
Jas5's Avatar
Jas5
Supercharger...and i dont think you need a new hood for s/c. I see lots of stock hoods with s/c
If you dont get a blower, you'll only feel a slight bump in power. Nothing like "HOLY **** SLOW DOWN" like you do with forced induction... (400-500hp). Guys with full bolts ons...cams...headers...CAI...tune..etc. They max out around 330-340 whp i believe (whp = hp to the WHEELS)
edit: LT = longtube headers
oh and not even sure if you have a v6 or v8
Old Apr 14, 2012 | 04:32 PM
Shift's Avatar
Shift
Shaker Hood you will need a new one yes. Because the Shaker sits right on the engine and takes the spot a Blower would. Plus you'd have a giant box hole in your hood. Its a good reason to go with a Blower and Cowl or some other cool hood of the sort. I have the stock hood with the Roush hood scoop and it just fits.
Shaker
Blower and Stock hood (My Car):
Old Apr 14, 2012 | 04:41 PM
Jas5's Avatar
Jas5
^yeah well it depends what kind of blower you have i guess... centrifugal = less heat, more top end power, less low end.... and no aftermarket hood required. Full boost around 3500rpm
Roots or whipple = more heat, full boost around 2000 rpm, easier install.
My 'centrifugal' Paxton blower (i suggest youtubing superchargers so ur not in la la land). The best thing about mine is I can swap the pulley (if I want more than 10 psi or 450whp), and go up to around 800-900 hp. Has an intercooler
Old Apr 14, 2012 | 05:09 PM
06stangia's Avatar
06stangia
Not going to s/c yet.
Old Apr 14, 2012 | 06:17 PM
MadStang40's Avatar
MadStang40
If you're looking for faster times, grab 3.7s or 4.10s, long tube headers, and cams. Also some rear suspension goodies to put that power to the pavement (lcas, sway bars, etc)
