Door panel removal
Old Sep 19, 2005 | 04:38 AM
mmmg's Avatar
mmmg
Default Door panel removal
Can anyone please help me in removing the door panels of 2005 coupe so that i can install new aftermarket speakers . Can u post some images how to install or atleast explain in words how to remove the door panel. Guys ...plz help me out becos atleast one of u might have installed aftermarket speakers in 2005 mustang...Will be waiting for ur replies ..thanks in advance
Old Sep 19, 2005 | 09:27 AM
old tsteffes's Avatar
old tsteffes
I ♥ Acer
Default RE: Door panel removal
I think that is has come up before. You might want to give the search a try.
Oh, here it is... https://mustangforums.com/m_694347/tm.htm
Old Sep 19, 2005 | 12:05 PM
JJSTANG's Avatar
JJSTANG
I took few pics and uploaded. Check the following link.
http://pg.photos.yahoo.com/ph/jjstan...pics/my_photos
1.Remove the sail panel.(PIC0049,PCT0050)
2.Remove the Door lock control **** bezel.(PCT0051)
3.Remove the interior door handle cover and bolt.(PICT0053)
4.Remove the window control switch housing and the door trim panel center screw.(PCT0054)
5.Remove the door trim panel handle cover and bolt.(PCT0052)
6.Remove the 8 outer trim panel screws and door trim panel.
# Speaker :JBL P8652(PCT0047)
# In-line crossover wrap in a sponge.(PCT0048)
I hope this help you.
JJ
Old Sep 19, 2005 | 01:50 PM
JJSTANG's Avatar
JJSTANG
I forgot to tell you one thing.
wire color
left door (driver side)
OG/LG (+)
LB/WH ( - )
right door
WH/LG (+)
DG/OG ( - )
JJ
Old Sep 19, 2005 | 10:28 PM
mmmg's Avatar
mmmg
Thanku very much for ur fast reply..I also found the pdf file from this forum .Now i will try to remove the door with the help of ur pictures and the pdf file..and install the ne speakers .Thanks again
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
b8checker
Sep 30, 2015 07:11 AM
