Sponsored by:
Sponsored by:
installing my ford raceing door sill inserts
Old 05-15-2012, 07:03 AM
2006mustanggtowner
2006mustanggtowner's Avatar
Default installing my ford raceing door sill inserts
i have a set of ford raceing door sill inserts for my mustang and i have them installed now with double sided sticky tape and they keep comeing up. i was wondering if anyone had any other methods of putting them in i was thinking an apoxy would work better? all help is much appreciated thank you
2006mustanggtowner is offline
Old 05-15-2012, 09:23 AM
kput
kput's Avatar
3M double sided automotive tape works better..
make sure you clean everything thoroughly with alcohol first.
on a side note, what color are your OEM sills, and would you be willing to part with them? (if they're black..)
kput is offline
Old 05-15-2012, 09:57 AM
TEXASGT/CS
TEXASGT/CS's Avatar
can you post some pics, i have been looking for some of the Ford Racing door sills. where did you get them from.
TEXASGT/CS is offline
Old 05-15-2012, 10:03 AM
kevinmalec
kevinmalec's Avatar
When cleaning the surface, make sure to use 90% or higher rubbing alcohol. The regular alcohol will not work as good.
kevinmalec is offline
Old 05-15-2012, 10:11 AM
gmoran1469
gmoran1469's Avatar
Originally Posted by kevinmalec
When cleaning the surface, make sure to use 90% or higher rubbing alcohol. The regular alcohol will not work.
Not quite.
Regular alcohol will work, you just need to make sure you wipe up the excess water that it contains. 90% pretty much evaporates fully because there is so little water in it. Regular alcohol will leave water residue with minerals in it that will prevent adhesion. As long as you wipe it up with a dry lent free cloth after you clean it then you are good to go.
gmoran1469 is offline
Old 05-15-2012, 02:28 PM
bigD1515
bigD1515's Avatar
Pics, pics, pics!
bigD1515 is offline
Old 05-15-2012, 04:10 PM
2006mustanggtowner
alright and yes ill get some pics up and my stock ones are silver sorry and i got them from the dealer i bought my car at a mechanic in the back said here want these haha
Old 05-15-2012, 04:11 PM
2006mustanggtowner
thanks for all the info
Old 05-15-2012, 11:38 PM
2006mustanggtowner
driver side
passenger side
Old 05-16-2012, 04:11 PM
SchneidyP4.6
SchneidyP4.6's Avatar
Wink
Shop Vac?
SchneidyP4.6 is offline
Quick Reply: installing my ford raceing door sill inserts
