O2 sensor issue from exhaust
ok guys so here is the big question:
I have a hole burnt in the line of my O2 sensor from the aftermarket dual saleen exhaust I installed on my 08 V6. Now every time I pump gas it spits some back at me, however today it didn't do it. Some friends told me that it shouldn't be an issue if I don't mind my check engine light being on. Is this true?
I just spent a crap ton of money on new mods for my baby (new subs, new bbk shorty headers, new intake) and I really don't want to spend the money on a new O2 sensor and having it installed (I've never done one before, but I think I could if someone explained it to me.)
Please offer some advice!
Thanks, Jessica <3
Thanks, Jessica <3
buy a new o2 sensor and locate where the burnt one runs... follow the line disconnect it and install the new one the same way the old one was....
i dont know mustang specific for I dont have one but my past 3 vehicles were easy to install o2 sensors...
so you're okay with spending money on modding the car how you want it, but not on fixing the things you're breaking?
that sounds like a recipe to hate your car in the not too distant future.
where exactly is the hole burnt?
its spitting gas back at you?
do you have cats?
tuner?
O2 sensor is bad, or you just dont have a tune for the exhaust?
whats the CEL for?
just trying to understand the question 1st.
welcome to MF, btw.
do you have cats?
tuner?
whats the CEL for?
welcome to MF, btw.
Entaille- I have had the car since to 2008 when it was purchased new, I basically can't afford to have it fixed right now because i had just purchased the mods. I love my car, it is more important to me than 1/2 the guys I have dated combined lol, I should have worded it differently. I just want a cheaper solution because I got hit with it after committing to large purchases like the headers and stuff! :-)
Onederful100- the hole is burn through the line of the O2 sensor, I figured it was a simple fix but apparently its way up under the rear end. I don't have cats, the car is kept garaged 100% of the time but it is a daily driver. I looked underneath yesterday and you can see where the exhaust caused a little burn in the wiring, it must have fallen down after I installed the exhaust. :-/ I want to know if it is really hard to replace and where a good place to get one would be.... Most autozone type stores want an arm and a leg for one.
There's no O2 sensor wiring near the rear end.
Your car would normally have 4 O2 sensors; 2 of them, with green plastic connectors in the wiring, up close to your shorty headers. The other two, with blue plastic connectors, are located past (or in) the cats (catalytic converters, that is).
Second, a burnt wire on a O2 sensor wont cause gas to be spit back at you when filling up.
Since your check engine light is on, you need to find out what DTCs its telling you. It may not be a O2 sensor issue at all, or maybe it is.
If you need a replacement, you can get ahold of a good used one for half or less than what a new one cost (send me a PM or post here, I have a couple extras).
Not to be blunt, but, if you love your car so much, try to understand what's right and wrong, and we can help you a lot more that way, and help you to get it right
Thanks, Jessica <3
Thanks, Jessica <3
Any burn on your O2 sensor wiring has nothing to do with gas being spit back out of the filler neck. That is actually a fairly common thing on the Mustang. When it happens just rotate the nozzle around and it should fill.
Take your car to an AutoZone or O'Reilly or someplace like that and find out what the code is. You need to know what the CEL is for. Is it something to be gravely concerned about? Who knows at this point since you haven't taken the simple way of finding out why it is on. It could be anything and it could be major.
