Programmer Timming Help
Old Jun 4, 2012 | 05:19 PM
mustangdog3's Avatar
mustangdog3
Default Programmer Timming Help
Ok, so i just ordered a DiabloSport Predator. where do i need to set the timming % at. What is the actual timming BTDC on a 09 4.6l.
Old Jun 4, 2012 | 06:14 PM
Nuke's Avatar
Nuke
You shouldn't be setting anything. The timing should be set by whomever is writing your tunes. When you ordered the tuner, you should have been asked info about your mods and what octane(s) you want the tunes for. The bulk of the power gains are from the fuel trim settings and a host of other parameters, the bulk of which are NOT end-user adjustable. Those things are for the guys that write the tunes like AM and Brenspeed.
If you ordeed the canned tunes from Diablo, then expect about 2/3 the power gain that you'd get from better tunes. Also, I think AM may have started writing tunes for the Diablosport. Most tuners no longer seem to support the Diablo anymore.
Old Jun 4, 2012 | 09:33 PM
mustangdog3
Thank you
Old Jun 9, 2012 | 01:40 PM
mustangdog3
Got my DiabloSport Predator programmer today. Got it installed and it works great. I used one of the custome tunes but what are spark and fuel adjustments used for. I messed with them but it ran like crap so I didnt use them. Just looking for a little info.
Old Jun 9, 2012 | 02:10 PM
Nuke's Avatar
Nuke
Those are user-adjustable IF you know what you're doing. Usually, if there's a problem with the tune, you call the tuner and he may have you make a few adjustments instead of e-mailing you a revised set of tunes.
Old Jun 10, 2012 | 07:35 PM
mustangdog3
Thanks.
Old Jun 10, 2012 | 07:47 PM
moosestang's Avatar
moosestang
Who did you buy this predator from? You should have purchased from brenspeed.com, evolutionperformance.com, bamachips, vmptuning, etc. There are a slew of performance shops that deal in mostly mustang tuning.
Old Jun 11, 2012 | 11:38 AM
mustangdog3
I got it from Summit Racing
Old Jun 11, 2012 | 01:55 PM
siggyfreud's Avatar
siggyfreud
You are probably running a canned tune then and could benefit from a Brenspeed or AM tune.
You seem rather new to tuning, so I'd very much avoid changing the spark and fuel parameters. Even with the knowledge, there is additional equipment (such as a wideband O2) that you'd want before undertaking that.
Old Jun 11, 2012 | 02:01 PM
kevinmalec's Avatar
kevinmalec
Did you receive custom tunes from Steeda?
Receiving a custom tune tailored for your car will get you the most performance gains.
