Traction control button
Old Jun 8, 2012 | 12:41 PM
BearKats15's Avatar
BearKats15
Default Traction control button
I know this is probably the dumbest question... But what exactly does the traction control do? I've experimented with it off. A little but I found no difference going around corners faster or in the rain
Old Jun 8, 2012 | 01:00 PM
Andy13186's Avatar
Andy13186
1 push of the traction control button takes off the traction control and you can spin the tires in a straight line, but advancetrac will kick in if you start to go sideways.
come to a complete stop with foot on brake and hold the traction control button for 5 seconds and traction control and advancetrac should be completely off allowing you to go sideways.
at a complete stop and push the button 2 times quickly will leave both TCS and advancetrac on but put it in a sport mode where they take a bit longer to kick in and apparelty it tightens up your steering a bit.
I usually just push the button once and have TCS off and advancetrac on , unless im planning on drifting. All these are what the settings are for the 2011 GT premium, i think the 2011 v6 has the same but im not sure.
Old Jun 8, 2012 | 03:14 PM
mph07alloy's Avatar
mph07alloy
Make sure brake pedal is depressed while preforming this function also or it won't activate sport mode
Old Jun 8, 2012 | 06:41 PM
AzPete's Avatar
AzPete
You can actually make changes while moving by just riding the brakes for a second when you tap the button.....works everytime on mine a a few others I have tried.
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
firehorse02
Nov 16, 2015 11:28 AM
lincolnshibuya
Oct 6, 2015 08:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
