2011+ V6 Exhaust Help!
There's an idea! Now back to YouTube to see if anyone has straight-piped their 3.7s.
If you want the beefier sound of a GT, you're gonna have to swap that 3.7 for a 4.6 or a 5.0. Sorry to break it to you, but the sound of a V6 will never replicate that of a V8. You will only get it to sound good for a V6. Sorry I can't help you with this one, I have a 4.slow so they sound different. And as far as X pipes and H pipes, X=raspier tone, H=beefier tone. And the HP differences of H and X is about a HP from what I've read, but who can even notice such a tiny difference. If you want to get it as beefy as possible, switch to an H-pipe.
You can't merge the two banks of three cylinders each of a V6 in a way that will make it sound like the two banks of four cylinders in the V8.
This used to come up often enough that I plotted a V8 and a V6 for the way the individual cylinders combine their pulses. The higher and more widely spaced peaks in red in the first plot is one side of your basic V8 rumble either as true duals or most 'H' type crossovers. It happens when cylinders that fire in sequence are in the same bank, and you briefly get heavier flow in that bank/pipe, and it's this sort of uneven choppiness that provides the characteristic V8 rumble. (If you listen really carefully from straight behind the middle of a car with a V8 and duals or an H-pipe, you can even pick out that the 'rumble' bounces back and forth from right to left - try it if you don't believe me.)
If you were to merge the flows completely the sound would look like the second plot. An 'X' comes close to this.
A V6 looks like this (↓↓↓), banks taken separately or completely merged. There is no way to produce the uneven choppy V8 plot with a V6 firing order because the normal V6 firing order never puts sequentially firing cylinders in the same bank.
I suppose you could redesign the crankshaft and revise the firing order to TRY to get V8 sound from a V6 - at great expense to yourself, and with a real risk of sounding more like a blatty old VW or H-4 Subaru instead.
Norm
Norm
Norm, that's a really good illustration. I can totally see how it illustrates the V8 rumble.
BigD, if the same is true for all V6 with off road exhaust, it'll have a lot more raspiness and it'll pop a lot more as well. Check out some vids on YouTube. I saw a video the other night of a 4.0 with off road exhaust. I thought it sounded pretty good while driving, but when it's just idling, there is a ton of popping.
I hope folks will forgive the "odd" and "even" bank notation - I first put that together when I was mostly involved with Chevy stuff, and I never got around to changing it to something more general.
Norm
Norm
Wow norm that's a fantastic illustration! Thanks for taking the time to do that! I always wanted to be "tech" smart with cars just like that. Well thanks for explaining that (: I'll just have to hope for a deeper sound with an X/H pipe. Apparently a guy at a shop near here is REALLY good at making cars sound incredibly good for what they are. Anymore advice is welcome! (:
first start up is at 4 minutes and thirty seconds. the very beginning is just the roush axle backs and then skip to 4 and a half minutes because the part between those two sections is the install...hope this helps
he has a different motor. the 4.0 sounds terrible without cats...i have an h pipe and slp loudmouths and its loud but its deep and throaty and i love it. when i trade in for a 3.7 im going to think about logtubes offroad x and roush axle backs like the link ill put in. if not a cut and clamp x pipe and the roush axle backs should sound good. from this video look up 3.7s with roush axle back only and listen they sound very good.
http://www.youtube.com/watch?v=bDAHD...hannel&list=UL
