whipple help!!
Old Jul 2, 2012 | 04:51 PM
07vbluestang's Avatar
07vbluestang
Default whipple help!!
i have the 07 whipple h.o. 550 and it just started to throw the wrench code a couple weeks ago. it comes on only after 5 minutes after start up. it goes into limp home mode. so i have to pull over and shut the car off and then restart and all is fine. i went in with my sct and no dtc's were found. it also seems like the wideband is rich, then lean, then rich and then lean. can someone please steer me in the right direction as what to start to look for. it has given a code p2135 which is throttle body position sensor switch a/b before also. should i maybe reload the dyno tune? also can i go back to the whipple procal tune and see if it does the same thing? i have added headers so i guess as long as i baby the car it should be ok to drive.
Old Jul 2, 2012 | 07:21 PM
moosestang's Avatar
moosestang
Did you solder the sensor extensions or butt connectors? I would solder all the wires if you didn't. It sounds like a bad sensor connection.
Old Jul 2, 2012 | 09:05 PM
07vbluestang
all the wires were soldered and then shrink wrapped.
Old Jul 2, 2012 | 11:19 PM
moosestang's Avatar
moosestang
With no cats it will probably be a little lean at WOT. just don't give it full throttle and you will be fine. How long have you had the dyno tune? How long has the whipple been on?
Old Jul 2, 2012 | 11:31 PM
moosestang's Avatar
moosestang
If your connections are good to your TPS and it's plugged all the way in, then I would probably replace it. P2135 seems to result in a tps replacement fixing the problem.
Old Jul 5, 2012 | 02:03 PM
07vbluestang
the dyno tune was with the cats. but it's been like that for over a year and had no issues. just recently getting the wrench lite. the whipple has been on for 3 years. i have gotten the p2135 before and just cleared it. i am going to replace it and see how that works!! thanks moosestang
Old Jul 5, 2012 | 06:51 PM
danzcool's Avatar
danzcool
Have you changed spark plugs at any point pr are they the same set that came with it?
Old Jul 10, 2012 | 05:15 PM
07vbluestang
they are the same plugs. it runs fine after i shut it off and restart it. there is no code when i go in with my sct. it doesnt do it everytime thou. i will limp it up to my buddies garage when it does it again and we will go in with his shop scanner!!
Granatelli Sales
Mar 21, 2016 06:16 PM
Bokeo
Oct 10, 2015 08:28 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
GWFoos
Jan 8, 2009 11:42 AM
01roush33
May 26, 2006 09:32 PM
