Misfire on #.8
Old Aug 8, 2012 | 03:55 PM
  #51
Mudflap's Avatar
Mudflap
Originally Posted by dmhines
Ouch ... That is my PCM code ...
Most of the #8's seem to be 2011's from what I have seen on the forums ...
Yeah don't panic yet, I have seen people claim that... but what I haven't seen is anyone reputable claim that...
Old Aug 8, 2012 | 04:13 PM
  #52
JThor's Avatar
JThor
Originally Posted by Phansm72
So has there been any idea what the real reason is behind the fail? Weak rings? Poor oil supply? I just bought a coyote with 3800 miles on it with one spun rod bearing, Im guessing it may be the rings and as a result burnt a lot of oil , caused pressure drop and spun the bearing.The Ford Tech said the motor ran great, no noise at idle just a slight rattle at high rpm , no misfire etc, plugs are burnt nice and clean too. Im pulling the pistons so Ill see how they look when I get there, planning on at least a new set of rings when I put it back together. Id like to adress the problem while Im in there and not have this pop up again once its all back together.
How many of the group has had a 4.6 spin a bearing or lose a piston in the first 5K miles? I find this amazing.
The old air cooled VW Beetles had a problem with losing #3(I think) cylinder. VW had to retard the timing for #3 to take care of the issue. I don't think VW ever formally acknowledged the problem either.
Old Aug 8, 2012 | 05:45 PM
  #53
moosestang's Avatar
moosestang
Never heard of a 4.6 spinning a bearing or losing a cylinder that wasn't supercharged and even then they were pushing it or it was a turbo.
Old Aug 9, 2012 | 09:29 AM
  #54
dmhines's Avatar
dmhines
I was wrong ... Actually my code is ZFK2 .... not ZFK0 .....
Old Aug 9, 2012 | 11:17 AM
  #55
Rob72's Avatar
Rob72
Originally Posted by IHateStangs
It is low compression in #8, every spark plug I put in comes out with oil...any fixes to this?
I'm a little late to the game but I might offer some new information OP.
Did you get a PO308? That is the specific code associated with the dreaded broken ringland on piston #8.
"Normal" compression readings on this engine can range from 170psi to 200psi depending on your altitude. All readings should be within 10% of each other.
It is normal to have oil on the threads of every spark plug on this engine. Not the part that throws the spark inside the combustion chamber.
Blue smoke should be coming out ot the tailpipes especially the drivers side if you broke the ringland.
Old Aug 9, 2012 | 11:35 AM
  #56
Mudflap's Avatar
Mudflap
Mine is ZFK2 as well...
Urambo Tauro
Jun 10, 2016 03:28 AM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
bconboy
Sep 21, 2015 12:52 PM
chrisc
Feb 10, 2006 10:16 PM
ghoste
Sep 7, 2005 11:42 AM
