Key trouble
Old Aug 29, 2012 | 08:25 AM
Antonio323's Avatar
Antonio323
Default Key trouble
I'm currently at work and I'm about to finish my overnight shift. I tried to put my backpack inside the car, but the key fob isn't unlocking the car. I'm guessing I may be needing a new battery. I tried to open the driver side door by inserting the key, but I just found out that's not possible either (You learn something new everyday). Should I call home to have someone bring the spare key or is there another way I can get the car open? I've waited an hour and a half and no luck yet.
Old Aug 29, 2012 | 08:41 AM
kevinmalec's Avatar
kevinmalec
Sorry to hear about your key fob issue. That is odd the key didn't work in the door either.....
Did you get it resolved?
A similar thing happened to my Wife's VW Passat, so I disconnected the negative connection on the battery for about an hour. I reconnected the battery and all went well and starting working fine.
I had a similar incident, after I recieved my car back from at the shop. It turned out, the mechanic did not fully tighten the battery terminal connection, so I tightened it up and everything worked as normal. =-)
Old Aug 29, 2012 | 08:45 AM
Antonio323's Avatar
Antonio323
It's still not unlocking the car. How do I access underneath the hood without being able to get in the car? Is it even possible?
Old Aug 29, 2012 | 08:48 AM
kevinmalec's Avatar
kevinmalec
That I am not sure of......Are you able to get the trunk to open with the key? find a way to get the backseat down to get into the car?
Old Aug 29, 2012 | 08:55 AM
Antonio323's Avatar
Antonio323
Only way to get the trunk open on a '10+ is with the key fob. I just opened up the fob and removed the battery for 5 minutes and it's working now! Thanks for the help!
Old Aug 29, 2012 | 08:57 AM
kevinmalec's Avatar
kevinmalec
Nice!!! I was just going to suggest removing the battery from the FOB key to possibly reset. LOL
Old Aug 29, 2012 | 05:21 PM
Nuke's Avatar
Nuke
I still don't understand why the key wouldn't open the door. I would have thought that the key is purely mechanical with no interactions or defeats from the electronics.
Old Aug 29, 2012 | 05:23 PM
alkemist's Avatar
alkemist
The only time this happened to me was my battery was dead and the lock was frozen stiff. I am curious as well...
Old Aug 29, 2012 | 05:52 PM
Antonio323's Avatar
Antonio323
I was also surprised by that. It isn't the first time that the key fob goes crazy on me like that. The two previous times I was able to unlock the door by manually putting the key in and turning it. For some odd reason, it wasn't unlocking it this morning.
Old Aug 29, 2012 | 07:35 PM
surfbum7190's Avatar
surfbum7190
I locked my key in the car with it runninng and opened the hood by going underneath the car, and using a leatherman i was able to unlatch the hood. this was on an 07, but you should be able to find the hood cable
