Key trouble
Old Aug 29, 2012 | 09:15 PM
JimC's Avatar
Super Moderator
Your key may not work in the lock because if you never use it the mechanism gets gummed up. Then the key won't turn (and for the person who asked how an electrical problem would affect the key, that isn't the problem I'm sure, it is mechanical). The locksmith told me to use WD-40 on the lock periodically and to use the key. He said don't use the graphite "lube" because it will clog things up by attracting junk.
Old Aug 30, 2012 | 12:48 AM
Antonio323's Avatar
Antonio323
I think you may be right, Jim. It's either what you said, or maybe I could have messed something up? I changed the door lock pins for the piston style chrome door lock pins. Maybe I accidentally pulled it out too much.
CS2007
Jun 25, 2019 09:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
ChampInSD
Oct 2, 2015 04:55 AM
logan409
Sep 26, 2015 07:43 PM
